I had a used BK2 flywheel and new disc and pressure plate. They were Valeo but the same as OE. New flywheel bolts and slave cylinder.
Shifts like a dream and no problems getting into gear or grinding.
Easy to shift as my Accent. I hope it can hold from slipping at peak torque.
As long as you replace everything with the 2013+ components (clutch, flywheel, pressure plate, release bearing) it will work just fine.
The 2013+ clutch assembly is designed to handle the additional power increase of the 2013+ models, and have been well know to handle 300ft/lbs without issue.
The weak point will be the flywheel now, rather than the clutch assembly slipping.
Duro
Duro
