1 - 1 of 1 Posts
BILSTEIN B14 - PSS Kit
The Bilstein B14 PSS Suspension allows adjustable vehicle ride height without the expense of a fully adjustable damping system. This system features both coilover and standard mono-tube gas pressure shock or struts with performance level valving for application specific, progressive rate coil springs.
The product benefits at a glance:
• Threaded body adjustable range of 20 mm
• Lowering of approx. 30-50 mm at front and rear
• Road-tested and fine-tuned by BILSTEIN ride engineers, under extreme motorsports conditions
• Aluminum Spring plates and lock nuts
• Surface coating using Triple-C-Technology®for long-lasting corrosion resistance
• Round threads for easy adjustment
• Quality sport springs made from highly durable material
• Gas pressure technology
• BILSTEIN monotube technology, made in Germany
TIBURON - 2003 - GK Chassis
TIBURON - 2003 - GT - GK Chassis
TIBURON - 2004 - GK Chassis
TIBURON - 2004 - GT - GK Chassis
TIBURON - 2005 - GS - GK Chassis
TIBURON - 2005 - GT - GK Chassis
TIBURON - 2005 - SE - GK Chassis
TIBURON - 2006 - GS - GK Chassis
TIBURON - 2006 - GT - GK Chassis
TIBURON - 2006 - SE - GK Chassis
TIBURON - 2007 - GS - GK Chassis
TIBURON - 2007 - GT - GK Chassis
TIBURON - 2007 - GT LIMITED - GK Chassis
TIBURON - 2007 - SE - GK Chassis
TIBURON - 2008 - GS
TIBURON - 2008 - GT
TIBURON - 2008 - GT LIMITED
TIBURON - 2008 - SE
GO TO NOPI BILSTEIN Catalog
BILSTEIN B16 - PSS9/PSS10
The engineers at BILSTEIN have created the ultimate race inspired suspension—the BILSTEIN B16 PSS9/PSS10. This innovative suspension system delivers unsurpassed driving performance.
The manually adjustable damping mono-tube gas shock absorbers feature 9 or 10-stage precise compression and rebound settings, from comfort to competition. The threaded body allows accurate adjustability of the front and rear progressive rate springs to achieve the vehicle ride height, center of gravity and level of performance handling desired.
The Bilstein B16 system puts you in complete control, providing the kind of precise suspension tuning formerly available only on race cars. From a weekend of competition to daily driving, this system provides perfect handling performance for every situation.
• Individual settings ranging from maximum Comfort to aggressive Sport can be selected by the twist of a dial (9 on PSS9, 10 on PSS10)
• Threaded body adjustable range of 20 mm at both axles
• Spring plates and lock nuts made from a special aluminum alloy
PSS9
TIBURON - 2008 - GS
TIBURON - 2008 - GT
TIBURON - 2008 - SE
Made in the GERMANY - Suspension Systems shipped FREE to lower 48 states
Contact the salesmen below or PM me for "HYUNDAI FORUMS" deal
1 - 1 of 1 Posts
