Hey, how y'all doing today? I've got a 2008 Hyundai Sante Fe with less than 83,000 miles on it. I recently had to replace the battery and now, my keyfob, interior lights, radio and clock aren't working. If you've experienced anything like this. Please advise
Please advise
I advise you to get a volt meter and use it to check the fuses on the dashboard fusebox. Don't remove any fuses. Just switch the ignition on and probe the test terminals on top of each fuse with the red meter probe...see below. Pay particular attention the the ROOM LP, CLOCK and AUDIO fuses. Are those being supplied with 12V?
Circuit component Automotive lighting Product Font Cable
When the issue which resulted in battery replacement came up, did anyone happen to give the vehicle a jump start (using booster cables ?) If polarity was reversed even momentarily, that could sure cause a lot of troubles all at once..
