My 2004 santa fe is a 2.4 L , 5-sp, am trying to place clutch/press plate, but trans/clutch assembly won't separate from engine block, engine with everything is out of the SUV. The block and bell housing separate about an inch then stops/then :crying2:stuck. Somebody please help....
Ahhh, everybody learns this the hard way. You must remove the actuator arm that the clutch slave pushes to actuate the clutch. Remove the pin which attaches the slave cylinder to the arm, remove the one nut off the top and pull the arm off. This will allow the clutch forks to swing free of the bearing and trans should separate with no trouble at all.
