Okay so lately Ive been having alot of road noise coming from my Left Rear tire. Alot of friends of mine said it sounds like the wheel bearing is bad. I was going to purchase the part myself cuz funds are low right now with school and all. Most of the time I tend to get most of my parts from rock auto, but the problem is will I need the hub and bearing assembly or just the wheel bearing??? I was going to just go to a place like firestone and just worry about the full cost but the price they charge for the same parts is nearly double. Also does anyone know I specific brand for the part that is good. Any information is much appreciated..
How do you know your tire isn't bad? Usually it's the tire. Switch them around front to back first and rule out a tire problem.
hmmm
well im at about 105K miles and the sound get louder as I accelerate plus there some slight vibration felt in the steering wheel also as speed increases. I thought maybe was the bearing cause the area I live in has a **** ton of speed bumps and not the rounded kind... the pattern speedbumps on the ground. The tires on the back were rotated/ moved to the back from the front recently and have 7/10 tread depth on both of them and the noise only comes from the left rear wheel. Unless tread isnt a factor... all signs seem to lead to the hub/bearing thing...
you're on the right track i think, but with car repair diagnosis is key. a lot of people get the urge to replace parts because that's what they think it is - only to find out its not. in the end you waste your time and your money, and that's not what this is about.
so here's a tip to confirm before you order:
jack up that side of the the car, remove the wheel. try moving the hub up and down by hand, i usually grab the studs. it should feel solid and not have any play in it. if there is, you have a bad bearing.
simple test :)
as i always say, when jacking up a car safety is paramount. use jack stands and wheel chocks - pump jacks lift and a car will kill you if it lands on you!
also, torque your wheels properly when reinstalling the tire. torque wrench is your friend.
Move the tire front to rear, see if noise stay or follow.. if follow the change of position, then it is a tire noise.. tires is less $$ than wheel brg.
If noise stay, then we can assume bearing,, but I am not there to drive and hear the sound too.
Front is a bearing replacement witih bearing and snap ring, and some press work
Rear is done as an assembly (hub/bearing)
