battery goes dead after car sits 2to3 days replaced alternator because it quit working has new battery found front marker lights on no been near car for 4 days
So the marker lights stay on with the key off and the headlight switch in the off position as well? You need a new headlight switch my friend. You could verify the drain on the battery by pulling the respective fuse, but that's what we call
"parasitic draw" of a much larger magnitude than the usual suspects.
thanks for the reply the tricky part is it takes a couple days before the come on and headlight switch is in auto position
Cordless telephones are a favorite pick for families during the past couple of decades, as a result of their ease and modern design. Enabling you to walk throughout the home rather than be tied to your telephone wired into the wall, making telephone calls is really much simpler than previously.
But thanks to numerous distinct models now available on the current market, you might have discovered that some cordless telephone batteries appear different for the ordinary cells and argos house phones.
Using landlines might be on the decrease, but a lot of families still decide to possess one; and when you are going to remain one in the home, it might also be a contemporary piece of technology!
Therefore, if you Want a helping hand in making Certain That You Have all the Ideal gear for your
If it turns out that the problem goes away after you take it out of "auto position", the cheap solution would be to just turn your lights on by yourself and stay out of auto.
