Sorry, can't help with replacement cameras.
But if you haven't already seen/found it, there's a good diy video on YouTube from our moderator Imstricken06 where he replaces his camera. Just search YouTube with that user name and you'll find the one I'm talking about.
It may be linked on this forum, too.
Good luck.
Myself and IMSTRICKEN is very familiar with it.
The reverse camera should be covered under the recall. If not. You can switch eBay to the UK site and look up the Santa fe reverse camera.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/162529764718
I purchased this exact camera. Original part. From the UK. Worked out the cheapest. Took me 2hrs. Buy a few clips for the trim as they break extremely easy. Once out replace any broken clips . Replace camera. Snap everything back together. There's a thread and a YouTube video IMSTRICKEN that I followed and posted about.... camera works amazing.
Good luck.
Sent from my SM-N950W using Tapatalk
Good luck.
Which recall?
There is a recall for the reverse camera on the Santa fe sport. I was re-imbursed back. You can certainly confirm with head office. They informed me and I took advantage of it since I replaced it. The recall is corrosion on the camera caused by salt water. The new cameras have been revised.
My 2013 Sport (full nav) backup camera stopped working a few months ago (Black Screen). Had been blurry for a bit and I was planning to disassemble and clean this spring, but unfortunately it took a complete dump I guess. I just called my dealer and also consumer affairs and there are no recalls or campaigns on the backup camera. They suggested I call back during regular business hours and talk to an escalation manager. I'm out of warrantee by a lot. (128k)
I'm thinking I could wire in the $32 Natika camera into the existing wiring connector
[ame]https://www.amazon.com/gp/product/B075ZPNL7J[/ame]
although I have to do a bit more digging on voltage of the OEM part. Not sure how the Windows CE system might handle different resolutions (if they are different), though.
I could seal things up with some sealant when installing onto the facia, as is shown on imstricken's excellent "how to replace" video.
OEM wiring:
Hyundai Santa Fe: Schematic Diagrams - Back View Camera System - Body Electrical System - Hyundai Santa Fe DM 2013-2018 Service Manual
Another thing I might try first is to dissassemble and clean out/dry the OEM camera internals and see if I can get the original part to start working again. Maybe there's just a bit of corrosion that causing a short. Worth a shot but unlikely to work, I know. If I have any success in anything beyond full OEM replacement part, I'll post here. I doubt I'd pony up $225 for the OEM part, though, to be honest.
