Just curious, I was wondering what's going to happen to the 2018 Elantra base, and accent, with no back-up cams after the law is in effect here in Canada after May 2018. I was wondering if the dealers will add a aftermarket type or will hyundia change the model?
Massachusetts was one of the first states to
discuss making hands-free use of cell phones mandatory in cars back in 2005. By 2008 I had hands-free in all my cars. Still waiting for the law to pass, but I like the hands-free convenience.
Back-up camera is not hard to install; if you can trim some wires, drill a hole and handle a screwdriver you can do it yourself.
As far as Hyundai, and other Asian and European carmakers for that matter, there are 3 levels: FIO, PIO and DIO.
FIO is Factory Installed Option, where the item is put in the car when originally assembled.
PIO is Port Installed Option. Since some things are only required in certain markets it's too expensive to install them in the factory, so when the car arrives in the port (for example, Long Beach for Toyota) the required equipment is installed there, freeing the factory from having to separate a few hundred thousand cars from the millions cranked out.
Then the DIO, or Dealer Installed Option. Things like backup warnings and such are included here; or let's say you "order" a car with an upgraded stereo; they pull the stock unit and put in a better radio.
My guess is, unless Hyundai starts adding back-up cameras to ALL their units, the Canadian required BUC will be installed when the car originally enters the country, unless it's a model that comes with it already.
BTW, for example, in Toyota's case, air conditioning in the 70's-90's was a PIO, since shipping 25,000 cars with the added weight was expensive. They could send over a whole year's supply of AC units with a "short" shipment and install them at the port.
