I am receiving B1620 SRSCM Internal Fault for my 2001 Hyundai Elantra GLS. My question is if I can simply purchase a working SRSCM and install it without further programming to fix this issue?
Thanks
Thanks
Have you tried to talk to the module? Need a scan tool and not a code reader.
Yes, as long as it comes from another pre 2004 Elantra which has the same SRS components as your car. IE, one from a car that doesn't have an external front impact sensor.
Thanks
More info would be nice. Did you buy it new? If not, was it bad when purchased? Been in a wreck? Carfax?
* Do a seach for your problem. A lot of stuff has been asked and answered.
