I have a 2008 Azera Limited with a rear sunshade. It works fine except that the switch (located on the console between the two front seats) jams. The switch has been replaced once by Hyundai, who said the old one was full of grit (it's possible - I own a dog who rides in the front sometimes). Since then I have been careful to avoid the grit problem. However, the switch is jammed again and I want to take it out and clean it or otherwise free it up, but I cannot get the console cover off. I can free up the front of it, but then it will not come off, being held in place further back by something I cannot find.
Any suggestions?
Thanks a lot, Ted.
How does that switch come out as my window shade does do anything, no motion and no noise of any kind. I have checked fuse and it is good so either switch or motor is bad I expect. I'd like to check switch if I can remove it to test it. Thanks
Mike
