1 - 16 of 16 Posts
I have an 07 Limited and lately the AWD isnt working properly, it tries to engage, the esc goes on, and then the AWD drive light comes on, and after a while it goes off, but will come back on when it tries to kick in the rear wheels into drive,
What could the issue be? Before i head to my app to get it checked out, next monday
as i understand....the awd system is only good up to speeds 25 mph and below. above that, it is not engaged.
you didn't specifically mention the scenario when this happens...but...that could be one of the culprits.
From a stop, when im trying to go on icy roads, it will try to engage, then the light comes on it and its in operable
I know its only good for slow speeds
you have a lock button on the dash...i'm assuming it is engaged.
for some reason, i'm betting this isn't like a rav4 or crv system...and definately not a subaru set-up, meaning, i don't think the awd will kick in automatically like the others do when it detects wheel slippage. i'm guessing that it has to be locked in for it to work.
if you have it locked in and it still wont' engage...and if you still have a warranty...it should be well worth a visit to the dealership to diagnose and get repaired.
In normal mode (AWD Lock not selected), the system functions like a FWD vehicle. If it detects a loss of traction, the system will automatically apply power to the rear (AWD mode) to regain traction, it will then return to FWD mode when traction is regained. The AWD LOCK function (when engaged) will apply power to all wheels for increased traction (similar to a transfer case/differential lock) but will automatically dis-engage above approx 20KPH to prevent damage to the system.
it happens regardless of AWD lock or not, just faster if its locked, and no the car is not under warranty any more
If it's the AWD light on the instrument cluster, then it's indicating a problem with the system. There should be a code set in the ECU but they are usually not accessible with a generic OBD scan tool. It could be as simple as a low fluid level in the transfer-case or impending sensor failure.
Discussion Starter #8
So i took it in today, after 2 hours they came to me saying they couldnt find the problem and waiting on Hyundai tech to help, 2 hours after they came back and said the Coupler needed to be replaced at a cost of 2030.00.
It also gave them codes B0E00 U3A00.
Im a little skeptical, not sure as sometimes it works and sometimes it doesnt
Any other advice
Any other advice
www.fourgreen.com - Hyundai/Kia - VERACRUZ - COUPLING ASSY-4WD - 4780024700
You can sign up to HMASERVICE, it free and you'll have access to a lot of information.
Any other advice
The system is basically a magnetic clutch (no servicing required)controlled by a 4WD ECU. You can always check the electrical connector on the coupler. Could be loose or contaminated.
Discussion Starter #11
thanks for the link, saving a grand on the part when i choose to fix it is great.
Where can i find out what the codes mean, i got another code today from my scanner and cant find it anywhere. U17E8
Also that HM service thing wouldnt let me sign up as ToS was blank and no where to accept it. (figure it out, needed to run it IE not firefox)
Veracruz awd problem
Hi i have exactly the same problem in my veracruz..... u find the problem???i change coupling and differential but the problem continues , I suspect it may be a sensor but the hyundai workshop could not find the problem I would appreciate any clues that might give me solution
Any other advice
Any other advice
One possible cause is the output gear on the transmission is stripped where is meshes with the transfer case, or the gear on the transfer case itself but this seems less likely. It gives both of those codes...I have photos but the drag and drop won't work for me here for some reason
I have the same problem with trying to find out what the codes b0e00, u3a00 mean and I have the same issues as above with the all wheel drive not engaging when the button is engaged. Also, I had the transfer case repaired and it did not fix the issue.
1 - 16 of 16 Posts
