The Aux (3.5mm port) connection has stopped working. The problem is the port itself. Anyone know the part number and where I can find a replacement?
NOTE: I've tested the components and their is no connectivity between the 3.5mm port and the pins directly behind the port. Connectivity from the wire harness to back of stereo is good, checked that.
This happened to me several times. My car is the Canadian 2009 GLS sport model which had the 6 speaker set up and the aux input was in the top right corner of the head unit. The aux input cut out so I took it apart and found that the solder connections to the aux plug of the head unit had cracked. I re-soldered the connections and it worked for another couple years before cracking again.
