Does anybody have a picture of where the Transmission Speed Sensor is at? I have this code p0715 Input/Turbine Speed sensor A circuit message. I paid a mechanic over $200 to fix and if this a simple fix I can save me cash.
Q in Sac
No pictures, but you have to remove the air cleaner box, then unbolt the transmission control cable assembly so it can be moved aside (not a big deal), then you can get to the speed sensor. Pop off the electrical connector (after figuring out how to do that without breaking it), take out the 10mm bolt holding it in, and then wiggle it out (sometimes a pliers is needed for this). Good luck. Buy one first so you know what it looks like, I got mine on Ebay for $28.75.
Dan
Dan
