MY SANTA FE 2005
I AM GOING TO REPLACE MY ATF WITH THE FILTER.
BUT I HAVE BEEN TOLD THAT THE FILTER IS IN SIDE THE GEARBOX SO ITS CAN NOT BE REPLACE WITH OUT REMOVING OUT THE GEARBOX!!!!!!
IS THAT RIGHT?:confused::confused:
Trans filter is inside the main case... We do not service them at dealer level, that is done at the rebuilding place when trans swapped for Re-Man unit.
It requires trans removal to table top, then partial tear down of trans to get at filter, bunch of clean up, RTV to re-seal case, and let it cure. then put trans back in car.
