When I have auto climate control off , and air condition off , temp set to 21, the vent still blows cold air , I have windows open , so I just want vented air not cold , anybody else have this problem
SENIOR MODERATOR
That all depends on the outside temperature at the time. When the climate control is turned off, outside air is drawn through the vents at outside temperature, regardless of where the temp was set before you turned it off.
Adjusting the temp has no effect if auto climate is off.
If you are sure that auto climate is off, and ac is off, and that the air coming out of the vents is not simply ambient temperature air from outside the vehicle, then you may have a defective unit. With auto climate and ac off, the air should not be getting cooled in any way before it comes out of the vents.
