Hi, just servicing my wifes Atoz, and not sure if there is a fuel filter or where it would be can anyone help?
thanks :whistling:
QUOTE (Bungfruit @ Oct 24 2010, 09:39 AM) index.php?act=findpost&pid=365841
thanks :whistling:
NS at the back just in front of the rear axles.
QUOTE (Bungfruit @ Oct 24 2010, 04:39 AM) index.php?act=findpost&pid=365841
thanks :whistling:
hy , get under the car , the fuel filter is in front of the rear left wheel, you can't miss it. be carefull how you tighten the fuel lines , i put a metal gasket in the wrong way and i lost about 10 l of fuel. be carefull ! and after you change the fuel filter put the ignition on and get under the car and make sure that there are is no fuel leaking from the lines.
