Now and ten the Atos will not start even though the engine turns.Had been to auto-electrician on 2 occasions, but he cannot find the problem (the ghost in the engine). I've read the comments of different people with varied suggestions. When the problem occurs out of the blue, I can wait a few minutes and then the car will start again without any suspect sound. If I fail to start the car, a push-start gets the car going. Has new battery. I've wondered about fuel injection and fuel pump as possible causes. Not enough power on the solenoid? Will some bypass to tyhe starter help? Bad connection between battery and starter? Help!!!!
SAMHIC1 : Joined Feb 2, 2015. Last Seen Feb 3, 2015. Number of posts to the forum : 1
I don't think he is gonna reply to you some how. Maybe you should just start your own thread to deal with your problem.
It might be the fuel pump that’s intermittent or if you have done a high millage it could be the fuel filter that needs to be replaced
