1 - 1 of 1 Posts
ARK Performance Inc. was founded 15 years ago, and is now one of the largest leading manufacturing facilities in the Republic of Korea for aftermarket performance products. Since the beginning, our main goal is to design and engineer high-end quality products that are reliable and proven for all types of professional motorsports.
At ARK Performance, we are devoted to offer you new and trend setting exhaust systems, suspension parts, engine parts, CNC machined products, and body exterior parts, that will always be superior in performance, design, and craftsmanship using advanced innovative technology. With the experience, knowledge, and passion, we are committed and value our customers and the industry with nothing but the best and up to date products.
DT-P Coilover Systems
Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The ARK system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride. The ARK DT-P Coilover system has been designed with professional road racing in mind offering extremely high value and performance.
Genesis - 10-12 - - Coupe BK - Height/Ride Adj - Spring Rate - Front: 12Kg /mm Rear: 10Kg /mm
Tiburon - 03-08 - - 2.7L Tuscani GK - Height/Ride Adj - Spring Rate - Front: 12Kg /mm Rear: 10Kg /mm
Veloster - 12-13 - - FS - Height/Ride Adj - Spring Rate - Front: 8kg/mm Rear: 6kg/mm
ST-P Coilover Systems
ARK Performance brings ground-breaking finest quality damper kits that give defined comfort and balanced corner handling. To sophisticate our drivers without loosing their performance results, ARK damper kits offer diverse series adaptable to specific driving conditions. ST-P Series, designed to adapt to all of your driving conditions, will create the harmony between power and stability which you demand. The full length adjustment system gives you the freewill to place various set-ups to meet your needs for specific road conditions. Hard rubber upper and lower mount designs in ST-P series absorb noises as well as vibrations to allow the cabin for quiet operation while still offering flawless suspension proofing.
Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
Elantra - 01-06 - - Avante - Height/Ride Adj - Spring Rate - Front: 10Kg /mm Rear: 9Kg /mm
Genesis - 10-12 - - Coupe BK - Height/Ride Adj - Spring Rate - Front: 10Kg /mm Rear: 8Kg /mm
Tiburon - 97-01 - - RD - Height/Ride Adj - Spring Rate - Front: 12Kg /mm Rear: 10Kg /mm
GT Series Lowering Springs
Note: Vehicle drop rate is based on the model and option of the test vehicle, and may vary based on each vehicle condition, and equipment option.
Genesis - 10-12 - - Coupe BK - Lowers - Front: -30mm / Rear: -20mm -
Sonata - 10-12 - - - Lowers - Front: -30mm / Rear: -30mm -
Tiburon - 03-08 - - GK - Lowers - Front: -30mm / Rear: -30mm -
Veloster - 12-13 - - FS - -
STRUT BRACES
Tiburon - 03-08 - - GK - Rear - AL6061 ALMINUM
Tiburon - 03-08 - - Version 2 GK - Front - RED - AL6061 ALMINUM
Tiburon - 03-08 - - Version 2 GK - Front - BLUE - AL6061 ALMINUM
Tiburon - 00-01 - - RD2 - Rear - AL6061 ALMINUM
GO TO NOPI ARK PERFORMANCE Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on ARK PERFORMANCE Products
1 - 1 of 1 Posts
