2016 Santa Fe SE Ultimate
I've been searching for an aftermarket cold air intake solution for my 2016 Santa Fe with the 3.3l v6 but nothing seems to exist. I currently do have a K&N high flow filter in there but wanted to see if there were any other options out there that some of you might know of. I've searched these forums and done some basic online searches but can't seem to find anything. Thanks!
the best option is the factory option. its already pulling in fresh air, and if you aren't tuning it, then theres no need to try and change the air box setup.
Make sense. I have always viewed an intake as one of the easiest upgrades on a vehicle so I just wanted to look into it. Thanks.
2014 Hyundai Santa Fe XL GLS Premium
Not sure there is a "universal" intake tube out there that would fit the 3.3 L motor as the mass air flow sensor is located right on the air filter container. I too have searched but have found nothing as well. Unless you 3d print an adapter that would accommodate the mass air flow sensor between the filter and the intake tube.
And also no need for the K&N filter, letting more dirt into the engine.
The stock filter has plenty of flow capacity.
The stock filter and intake likely reduce wide open power less than 2% (8" H2O vacuum), versus zero restriction.
So very little to gain modding a stock engine.
  • Like
Reactions: pmillion
