hi.. I recently tried to play some songs using a USB stick. At first it worked but when I started to scroll through the songs the following message popped up and now the USB stick won't work at all. I've tried 3 different USB's to no avail.
"Application Error - Application Mona15.exe encountered a serious error and must be shut down:
I have turned the car off and left it for awhile but the same things happens when I try again. I have previously used at least one the USB sticks in the past without issue.
Any suggestions would be welcome.
Discussion Starter · #2 ·
Just to let you all know I found the reason for the "Application Error - Application Mona15.exe encountered a serious error and must be shut down".
It was the USB stick as some of the songs on it would not play so I had to go through and delete each individual song that had an error and now it works perfectly.
Thank you to the Suttons City Hyundai Service Centre in Zetland, NSW for their advice.
