I have a torn boot on the passenger CV Axel.
A while ago my drivers side (left) went and I found buying a pair of axels from Carid was a good deal. Replacing the drivers side was easy and the same as all other FWD cars Ive replaced the CV axel. Held into the transmission side y a small snap type ring at the end of the axel. A slide hammer or pry bar pops it out.
On my LF 2017 Sport 2.0T ( and I think it is the same for the Limited 2.0T) the passenger side the CV axel inner does not go into the transmission. Hyundai used a short "half shaft" out of the transmission to a support and bearing and then the CV connects to the "output half shaft. The CV Axel inner is a female the output shaft on the car is a male.
Does it just pop off the output half shaft? Use a puller or pry and it will pop out like the other side? Or does it connect at the outer bearing support for the output shaft?
Before I get it apart and find out I need a different tool Id like to confirm that I just give it a pop and it will come out. I want to do it after work this week and cant afford to not get the car back together same day. The drivers side was breeze did not even take off the calipers or strut. Just axel nut and lower spindle clamp and was able to pull it out of the way and reach in with a slide hammer and pop the axel out of the trans.
see diagram below #1 & 5
Thanks for any help.
