1 - 10 of 10 Posts
· Registered
'19 Santa Fe SE 2.4L
I have a 2019 SE and started hearing a knock from the car this morning. As far as I can tell, it seems to be the struts. I'm right at 58K miles and was wondering if anybody else has had to replace the struts and/or shocks yet.
· Registered
Time to get to see your dealer. you only have 2,000 miles left on your warranty.
· Registered
2015 Sonata Limited 2.4 GDI non turbo 40k miles Kona EV 2021 15k miles
I don't see how a worn or faulty strut would be knocking. A broken spring will, or a failed end link. Also check your wheel lugs. Check for something lose inside the engine bay and inside door storage.
· Registered
2022 Santa Fe Calligraphy 2.5T
It is common for a worn or faulty strut to knock or clunk. This is very much the same noise as a faulty shock absorber. The noise is due to the additional, uncontrolled, travel. The mileage seems low for a bad strut though, so I would agree with your assessment to check the simple things like lug nuts or end links.
· Registered
If you replace the strut and not use OEM you will be disappointed in the ride. More than likely the upper strut bearing or link (like others have said).
1 - 10 of 10 Posts
