1 - 9 of 9 Posts
Even though my Iphone is connected and I can use it hands free I have found that I cannot stream audio from it sometimes. I press the media button and only CD is available, not phone music. If this happens to you just press the phone display button, push settings button, then streaming audio. It will display two selections, audio enable and audio disable. It will show that it is enabled, push disable, then enable again. Next press done. Now press the media button and your phone music will be one of the selections available. Don't know why this bug is there, but this is a work around.
Thanks for the advice !!
I've had my Azera since last April. Streaming music worked fine for months without any issues. For the past two months or so it started to get touchy. Sometimes it would work, sometimes it wouldn't. Switching streaming audio off then on worked the first couple of times then it wouldn't work anymore. Then I switched Bluetooth off/on and that worked a few times, then stopped. Re-starting the car didn't always work. So far the only thing that works is re-booting the phone. So far, the past several times it's done this the phone re-boot fixed it.
Hope I am not headed down that road. The disable enable thing has worked for me a half dozen times or more. Rebooting the phone kind of points to the problem being with the phone possibly.
I was thinking that too, however I used to be able to fix it by switching the car settings off/on. It might be a little of both, the car and the phone. Even though it sometimes will not stream audio, it always stays connected via Bluetooth for phone calls.
Hi -
My phone connects to my Bluetooth in my car allowing me to make calls and only listen to the audio usic playing off of my phone. However, my phone does not show the title of the song or artist or any information at all it just says its Streaming audio" from my phone. It also doesn't connect when I enter into my maps a route etc. in my phone (which is bluetoothed). Ive seen on my brothers Hyundai around the same year (his is a Sonata though) and when he connects his phone he can see everything on his screen -- the music name, artist, maps, the works. Am i missing something or doing something wrong or do i need to set it up a certain way?
Please help!! Thank you in advance.
1 - 9 of 9 Posts
