So I removed the antenna from the roof in order to seal a water leak that was dripping into the cargo area. Somehow I managed to destroy the connector for the FM wire that plugs into the antenna mast.
I guess I'm going to have to run a new antenna cable from the aftermarket Sony head unit back to the antenna mast. Does anyone know if this is a standard/ generic antenna cable? Or is it a Hyundai specific connector that plugs into the antenna? I can get an adapter with a right angle connector to match the one I ruined, and a 20 ft. antenna cable, as long as there is nothing special about the OEM version...
Does anyone know?
