Which head unit would you go with?
  • Total voters
  • Poll closed .
41 - 60 of 66 Posts
Discussion Starter #41
Snapped a quick picture to show off the appearance of the Car Launcher (explained in previous post) as well as the interface for the climate controls.
449199
Discussion Starter #43
So interesting... because they sent me that adapter and I didn't need it hahaha 🤣 🤣 . Just goes to show how slightly different our models can be. Hopefully this indicates you may have better luck with the harness than I did. At least its an easy fix and you can make the argument to have them send you the USB and FM asap. Did you get more than one wiring harness and canbus like I did?
Discussion Starter #45
Discussion Starter #48
Pics of the two harnesses I received
Ya ours are more similar than I thought. I can't tell from your picture, but it looks like your black harness is a bit different than mine. It fit the 2 white factory connectors for me though.
110318720_284890576151016_1767535580590693958_n.jpg 110702317_608883249745423_5557844400229512046_n.jpg Screenshot from 2020-07-22 11-04-16.png 103694617_261329408476224_4515623603912853868_n.jpg
The black harness I have is too big to accept the two white plugs thanks for the pics I was just about to ask for a part code!
Discussion Starter #54 (Edited)
ya, looks like it has all the speaker wire (purple, grey, white, green) built into the right side of the black connector in the main pic. That's likely the one I got, which unfortunately isn't the correct one for my vehicle lol
--make sure you check out the camera connector as well (your third white connector with 4 wires)
No response from the seller in 24 hours when you say you went to support do you go via AliExpress messages?
Discussion Starter #56
Yes. They typically responded overnight for me.. other than weekends. Maybe they are spinning because they still haven't solved my problem lol.
I'll give them until tomorrow am, messages showing as unread on their side. I checked out the other harness I have and its for a Jeep Cherokee!
So just as I was about to pull the trigger and raise a dispute they messaged to say "We'll sent it" so go know what they're sending as I've requested the USB adapter, FM adapter and correct harness.
Discussion Starter #59
That's good news. I asked about my new harness and USB adapter as well, hadn't heard anything since 7 Jul. Turns out they shipped everything on that day.. can't say I'm overly confident in the new harness... :LOL:
41 - 60 of 66 Posts
