1 - 16 of 16 Posts
2022 Tucson Hybrid Limited USA Market, Amazon Grey/Black With full OEM Spare
Is there anyway to get rid of the static split screen?
I have seen videos that the split screen is scrollable and removable with car play.
Could of been earlier firmware or maybe only with Car Play.
Gadget Television set Flash photography Television program Cameras & optics
Font Astronomical object Gadget Science Rectangle
2022 Tucson Hybrid limited USA
Font Display device Screenshot Multimedia Darkness
Font Electric blue Display device Multimedia Event
Considering 2023 Tucson PHEV
It adds the control ability to swipe and "remove" the split when you enable it. Otherwise, you always get what you've shown. Anyway, it's quick to try and then switch back if it doesn't do what you want.
Nice screen shots.
From what I've read on here, I believe for Android you cannot get rid of the split; you can only change the widgets.
Discussion Starter · #8 ·
Not only can't get rid of the split, it's unscrollable, as in static.
2022 Hyundai Tucson N Line 48v Hybrid
Hi everyone! Also, have a question about how to use the split screen.
But I have a problem - there is no such option in Phone Projection Settings as the Split screen for AA.
Any thoughts? 2022 NX4 Patrol Tucson.
Hello there!
In my 2022 NX4 Hyundai Tucson N Line (48V Europe), I am able to access the AA Split Screen by following the below procedure:
Step 1. [Very important] Connect your Android Device to the vehicle with an original USB cable via the USB Type A Port marked "USB" under your infotainment system (see the attached photo)
Step 2: From your vehicle infotainment system homepage, go to Settings -> Theme/Layout settings (see the attached photo)
Step 3: The sub-menu Theme/Layout settings are: (see the attached photo)
-> Screensaver
-> Split screen
-> Cluster theme
Please let me know if this works well for you.
Best regards
1 - 16 of 16 Posts
