1 - 8 of 8 Posts
hi Guys
can anyone tell me the procedure to reset the airbag light on my Accent?
i had the steering coloum out and after re installing i've had the light come on
Cheers
Darren
You need to visit a garage and have them erase whatever trouble code has been logged in the SRS control module.
Or buy a proper scan tool and erase it yourself.
No, a generic OBDII tool isn't able to link with the SRS. OBDII tools can only scan the engine PCM.
I think the cheapest tool that can scan the SRS (and the ABS/ESC) is the Autel AL619. It was about $120 on Amazon last time I checked.
So you had the steering column out. I think you may have now broken the clock spring. Yes you need a good scantool to read and erase the code.
1 - 8 of 8 Posts
