My first post here. I bought a used 2006 Sonata a few days ago and it had the main dash airbag warning light lit. It just came off service in a rental fleet and it seems to be in excellent shape otherwise... really enjoying the car so far.
Took it to the dealer today and they said it was just a "history" code - B1448. They cleared it and said there were no circuit failures and that everything was "OK". I don't have much confidence in it not returning. I'm sure it's just a matter of time until it happens again unless the cause it corrected.
I found a description of this code on some obscure site (not hmaservice) and it says this means "Occupant classification sensor defect".
Is this the sensor in the passenger seat? Would it be helpful to unplug the connectors and spray them with contact cleaner, etc ?
Here's the list of airbag warning codes that I found. Not sure if they apply to all models or what years, etc. Maybe someone else can comment.
Hyundai - Air Bag Restraint Systems
DIAGNOSTIC TROUBLE CODE IDENTIFICATION
B1111 Battery voltage high
B1112 Battery voltage low
B1338 Front impact sensor defective
B1339 Front impact sensor communication error
B1346 Driver-side air bag resistance high
B1347 Driver-side air bag resistance low
B1348 Driver-side air bag short to ground
B1349 Driver-side air bag short to battery
B1352 Passenger-side air bag resistance high
B1353 Passenger-side air bag resistance low
B1355 Passenger-side air bag short to battery
B1361 Driver seat belt pretensioner resistance high
B1362 Driver seat belt pretensioner resistance low
B1363 Driver seat belt pretensioner short to ground
B1364 Driver seat belt pretensioner short to battery
B1367 Passenger seat belt pretensioner resistance high
B1368 Passenger seat belt pretensioner resistance low
B1369 Passenger seat belt pretensioner short to ground
B1370 Passenger seat belt pretensioner short to battery
B1378 Driver side impact air bag resistance high
B1379 Driver side impact air bag resistance low
B1380 Driver side impact air bag short to ground
B1381 Driver side impact air bag short to battery
B1382 Passenger side impact air bag open
B1383 Passenger side impact air bag resistance low
B1384 Passenger side impact air bag short to ground
B1385 Passenger side impact air bag short to battery
B1387 Driver seat position sensor short to battery
B1388 Driver seat position sensor short to ground
B1389 Driver seat track position sensor defect
B1390 Passenger seat track position sensor short to ground
B1391 Passenger seat track position sensor short to battery
B1392 Passenger seat track position sensor defect
B1400 Driver-side satellite sensor defective
B1403 Passenger-side satellite sensor defective
B1409 Driver-side satellite sensor communication error
B1410 Passenger-side satellite sensor communication error
B1447 Occupant classification ECU defect
B1448 Occupant classification sensor defect
B1449 Occupant classification communication error
B1450 Occupant classification wrong identification
B1481 Second stage driver-side air bag resistance high
B1482 Second stage driver-side air bag resistance low
B1483 Second stage driver-side air bag short to ground
B1484 Second stage driver-side air bag short to battery
B1485 Second stage passenger-side air bag resistance high
B1486 Second stage passenger-side air bag resistance low
B1488 Second stage passenger-side air bag short to battery
B1511 Driver seat belt switch short to battery
B1512 Driver seat belt switch short to ground
B1513 Passenger seat belt switch short to battery
B1514 Passenger seat belt switch short to ground
B1515 Driver seat belt switch defect
B1516 Passenger seat belt switch defect
B1620 SRSCM internal fault
B1650 Front crash recorded
B1651 Crash recorded driver side impact air bag
B1652 Crash recorded passenger side impact air bag
B1657 Belt pretensioner deployment
B1670 Second stage crash recorded
B2500 AIR BAG warning light failure
B2502 Tell tale light failure
M
Guest
That's kind of what it sounds like to me, like the sensor is messed up and can't tell if there's an adult or child sitting in the seat. I'd take it back to the dealer with the list you found and question their findings. If they stick to their guns get their findings in writing - this way if someone is injured by an airbag either not coming out out full force, coming out at full force when it shouldn't, or not deploying at all the ball will be in their court. Then again I'm far from an expert and it could be something totally different. Is the light still lit or did it light again ?
Thanks for the list too - I'll put it on the TSB site. :thumbsup:
The light hasn't come back on (except for the normal 6 seconds at startup) - but it's only been one day. If it does come on again and I have to take it back to the dealer, hopefully it will be obvious that it's not just a freak code and that there is a real problem that needs looked into. I'll be insistent that they don't just reset the code again without looking for the cause.
Dear Greg,
I just recently paid to get my passenger (occupant) seat air bag seat sensor replaced. It was quite expensive, and my 2001 Sonata was not covered under warranty for this defect.
I am very interested if your code does come back. I failed to ask the dealer what the code was...shame on me. Maybe I could have had it reset, and tried my chances that the code would not come back.
Byron
Hi the airbag light on my trajet lights permanently when you start the engine. I have brought to hyundai to check and they said it has codes b1620 srsch internal failure, b1661 srsch unmatching, b1361 and b1367. Is there any way to rectify this without buying a new ECU unit?
