I found a post in the forums with a similar issue to the one I have the only difference is that I have a Sonata GLS 2012:
"one of the "slider" control knobs on my '04 sonata has broken and i need to replace it.
i'm not sure i'm calling it by the right name; i can't seem to find it anywhere when i google it.
it's the small plastic piece in the middle of the air vent that controls the direction of the air flow.
any help or a link to a supplier would be greatly appreciated!
thanks so much "
Taken from Crosby1
link: http://www.hyundai-forums.com/194-y2-ef-1989-2005-sonata/146589-air-vent-slider-control.html
Does anyone know if this is a replaceable part ?
If so where can i get it, and instructions on replacing.
Pictures available if needed.
Should I just go to the dealer to fix it?
I have the same issue and i am going to try the hyundai warranty??
In case of vent slider broken you can change it, no requirement of change whole vent. Just replace the tab it is cheaper. You can order online according to your model name. check here Venttabs.com here you can find tabs.
thank you!
thats a good find
this is a three year old problem thread but you found a great solution!
