2005 Tuscon. The A/C just stopped working. It looks like the compressor clutch is not engaging. I checked what looks like the fuse on the side of the dash and the relay under the hood. I don't have the schematics and was wondering if there are other fuses or switches to look for? I will be going under the hood today to check for voltage at the compressor. If I have voltage at the clutch and it's not engaging that would mean a bad compressor, right?
I don't know if this is related or not, but I discoverd this problem after one day when the battery went dead for no apparent reason. Battery one year old, charged and now is fine.
Thanks
Barry
It could mean your refrigerant has leaked out someplace, since the compressor won't come on if there's no pressure in the system. A lot of times a stone put a hole in the condenser and the springs a leak.
Need sufficient R-134 to trip the pressure switch which is input to PCM, which in turn fires the relay, and the relay completes power circuit to field coil.. Look for a 10A fuse in the engine compartment fuse block marked AC I think...
You can look at data stream on GDS and see the inputs to PCM and PCM output to relay..
Have seen a couple wire issue between block and field coil, and a field coil that was indeed open circuit, and a few connector issue at field coil..
