Lot's of talk elsewhere around where is the air cabin filter and ionizer I keep hearing about in the Palisade SEL and up trim levels. Very hard to find anything in the owner's manual so I followed up on my suspicions and found it today.
1) OPEN GLOVE BOX and EMPTY CONTENTS (you'll understand why in a moment)
2) There are 2 'TURN CLIPS' on each side that act as stops. Simply TURN TO REMOVE.
3) There is an "ARM" on the right side attached to the box, once you pull this away (towards the door) the glove box with fall vertically. Aren't you glad you emptied it. LOL
4) Now you will see the "ACCESS DOOR" for the cabin filter. There is a "pinch clip" on the right side. Pinch and remove the door.
5) This reveal the CABIN FILTER. Simply pull towards you and remove.
And that's generally where they all are. Wherever the blower motor is, they'll be on the air intake above it and that's usually the glove box
Most of my previous cars (GM) were actually on the firewall under the wiper blades.
