1 - 19 of 19 Posts
2021 Hyundai Elantra N-line
Decided to make a list of aftermarket parts for the Elantra, Elantra N-line, and the upcoming Elantra N.
We shall begin down below:
Piggyback ECU:
JB4:
https://burgertuning.com/collections/kia-hyundai/products/jb4-for-kia-hyundai-2
Only works on turbocharged cars. You can ask to see if they'll be able to work on the 2.0L N/A engines though.
Suspension:
-----Coilovers-----
•HSD Coilovers | Mono and twin-tube versions available |
-----Lowering Springs-----
•Storm Lowering Springs
Fits:
1.6T and 2.0L
Oil Catch Cans:
Sxth Element Oil catch can:
Fits:
1.6T
Intakes:
1.6T N-line:
2.0T N:
-----Throttle bodies---
1.6T N-line:
•Big Bore throttle body
2.0L Regular:
BOV/BPV:
(Blow off valve / Bypass Valve)
---Blow off valves---
1.6T N-line:
•Plug & play Blow off valve (BOV)
Fits:
1.6T N-line
Big Brake kits:
•OEM factory big break kit
Fits: 1.6T and 2.0L with no extra modifications needed though, you may need bigger wheels if you own an 2.0L because they're 13.6 inches big.
Rigidity/Handling improvements:
Strut bars:
Fender braces:
Fits: All
That's all for now
Websites:
R1 concepts
Shark Racing
Tuscani customs
SXTH Element
Burger tuning
The more things that become available, the more I'll update this list and improve it.
Every car is different. Some are quite a nightmare to build. As someone who has made downpipes before, some are much much worse than others. Probably worst 2 I did was a Celica All Trac turbo (SOOO tight) or possibly the 05 Subaru Legacy GT (SOOO many bends).
So far, I've found a couple of things available for the N-line which are:
Throttle bodies:
Blow off valves:
Brakes:
R1 concepts rear brake disk. No fronts for now.
Hi-flow cats:
•High flow 200 cell race cat
Water pump pulley:
•1.6L water pump pulley
That's all for now
Websites:
R1 concepts
Shark Racing
By the way, SXTH Element is already working on something for the N-line. And it makes 188HP.
Update: new intake from SXTH coming late August for our N-line. BOV is in the makes. Same goes for intercooler.
just Got a 2021 n line manual. Don't know much about it butI am waiting for the aftermarket to get a little better for it. I have a question what is the water pump pulley for?
1 - 19 of 19 Posts
