1 - 1 of 1 Posts
I got a chinese unit. Usb and reverse trigger wiring is the main focus here.
I have this if this helps:
I have left my latest post at https://www.hyundai-forums.com/threads/wiring-harness-c-connector.499817/post-4536825
But i feels i can get better answer on my own post. Maybe will help a lot.
I think i have to find this usb/ipod connector and tap into the separate usb cable so i can connect it to the unit.
This chinese unit alreasy has ix45 non navagation bases wiring done with a matching female connector for a and b. I have no c connector.
Here is thing, where do i connect this reverse detection wire to the r gear shift? I dont have the navagation so the schematic is bit different.
http://www.hsfmanual.com/audio_unit_components_and_components_location-777.html first head.
Pin 9 on this head shows detent blue wire. Pin 11 is left front speaker negative. On navagation bases, it has r position at pin 9 with rear camera power at pin 11.
You will be a huge help, thanks :)
1 - 1 of 1 Posts
