Hi All
I am busy fitting a after market cruise control and having trouble. The is one scenario where the supplier say that the wires that connect to the brake switch should go to the +12v and then the other wire to the lamp supply wire and when I do a continuity test with the brake pedal not engaged I should get a reading and then when I step on the pedal I should get a zero reading. However I get the opposite. When the pedal is not pressed I get zero and when it is pressed I get a reading. Anyone fitted an after market unit before?
This is for iMax 2016 Petrol Auto and the unit is a Command Auto AP60B
Thx in advance.
Contact the Command Auto customer support. They must be able to help you with this.
I have numerous times and they are very helpful. They even got the unit send back to them for testing and returned it and after multiple calls and diagnostics it came to the above that we cant figure out and they did confirm other installs of this unit on same vehicles.
