Hi there, I recently replaced both CV drive shafts on a manual Elantra 2003, The replacement went fine and the car no longer makes clicking noises on turning. However now the ABS light is now on permanently and also the brake light comes on sporadically have checked fluid levels and flexible hydraughlic cables for leaks and there are none.
During the replacement I undid the ABS sensor cable and was careful not to stress the cables, also I have taken the wheels off both sides again and inspected everything carefully as well as measured both ABS sensors with a meter and the both read 1.5Kohms which is about right (so I assume I didnt break a cable.)
Any suggestions what could be causing this? As I say the car drives normally, Brakes are completely normal though I haven't stomped on them to test to see if ABS actually works.
Any suggestions, failing this...:
I would like to plug a OBD2 reader and see what the fault code is but none of them seem to support this age vehicle (not the cheapys on EBAY anyway)? Anyone know of a cheap one that will work with this car that can read and reset ABS codes please.
