Someone told me that I needed to add water to my battery occasionally...?
If so, how often, how much, and how would I even check?
I've never heard of adding water to the battery, but it sounds like "blinker fluid."
Or, something I should not attempt myself for any reason.
Still want to be aware of that learning curve, in case.
Thanks!
These cars have an AGM battery. Different than the old lead acid batteries where you add water. Here is some info on AGM batteries I found out when I almost killed mine.
FYI on OEM AGM battery
Mine finally died. The AGM one for these cars are more expensive and less available than the old lead acid ones.
When it dies you buy a new one. No maintenance that I know of. You should use a battery charger designed to be used for an AGM battery if you need to charge it. Fortunately, I had one when I needed it.
