Good Day,
First post.... Hi.
Question: The fuel pump relay is as I understand it in the same housing as the ECM on the passenger side footwell. It is however a devil too gain access too (I've looked at it from all angles) and I need to disconnect the relay in order to release pressure too allow me too change out the fuel filter (She's now on 170 000 km+). Is there a more readily accesable fuse which I can disconnect which will have the same affect, without causing ECM issues and re-calibration?
1. Typically you just remove the fuel pump fuse to disable the pump.
2. To discharge the pressure let you car sit overnight in garage or use the fuel pressure dump valve on fuel rail. be careful not to start after dumping fuel pressue. You can end up with fuel in engine bay. Do not perform the fuel pressure dump with hot engine.
3. The fuel filter for most Hyundai’s are internal to fuel pump inside the fuel tank, under the back seat, under access panel, after removing fuel pump, disassemble to access fuel filter.
no wonder hyundai issued service bulletin decades ago to add Chevron Techron with each 5K oil change and full tank of gas. The fuel filter is a pain in the @&&.
best wishes
Thanks, not familiar with the fuel pressure dump valve. I'll check it out.
unplugging the relay is not going to release the pressure unless you are trying to do this while the car is on. If you're concerned about the pressure, look in the engine bay for a test fitting on the fuel rail and press the valve in.
as for the filter you will probably need to plug the line so it doesnt siphon out of the tank when you disconnect it.
