Sometimes my Accent will run rough and cut off when I come to a stop, then when I crank it up, and it will crank up with no problems, it will run real smooth for awhile.
Hi buddyduck. If you can check the car for stored trouble codes, that would be the easiest place to begin. The Crankshaft Position Sensor failing is also a common problem that can cause stalling or hard/no start conditions.
running rough and stalling at idle can also indicate air intake leak somewhere. the intake manifold gaskets on the LC accents are known to crap out, wouldn't doubt it on an X3 as well. error codes are essential here. it will be reporting something at this point.
Hyundai Forum is a community for all Hyundai Owners to talk and learn all about their favorite subject: Hyundai cars from the Sonata to the Elantra and even the new Kona!
