I have an 01 accent with a 1.5 engine. Coming up with codes
P1123 and p1128. I sprayed manifold with brakekleen and didn't get
Any change in Rpms. Also sprayed maf sensor with maf cleaner
And still have same problems. Some hesitation when I start to go
And while I'm driving. My gas mpg is 25 mpg which seems way low
I just bought car and next day engine light came on with above
Codes. What do I check to fix this problem
I sprayed manifold with brakekleen and didn't get Any change in Rpms.
great troubleshooting step! applause!
so you're on the way to eliminating one cause: vac leak. check all the hoses as well.
the P1123 code indicates a problem with the throttle position sensor:
P1123 Throttle Position Sensor In Range But Higher Than Expected OBDII Engine Light Trouble Code | Engine-Codes.com
and the second indicates you're running lean:
P1128 Hyundai Fuel System Lean Part Load OBDII Engine Light Trouble Code | Engine-Codes.com
i'd say this is pretty conclusive. TPS is not returning correct signal and is affecting your air/fuel mixture. its not a bad idea to consult www.hmaservice.com and use the correct diagnostic procedure there under DTC, but i think you need a new TPS.
01-36-022
DESCRIPTION:
To diagnose a 2000 or 2001 1.5L Accent Diagnostic Trouble Code (DTC) P1128 (FUEL SYSTEM LEAN -- PART LOAD), check the following:
Check the intake system for air leaks.
Check that the Mass Air Flow (MAF) Sensor (P/N 28164-22610) operation meets the specifications listed below. If the MAF sensor output is significantly lower than the reference value (10% or more), then replace the MAF sensor.
WITH AUTOMATIC TRANSMISSION
Table 1: Using the Hi-Scan Pro in the Hyundai Diagnostic Menus Current Data Screen
TPS (%) 0
3.5
5.1
7.4
MAF (kg/h) 10
21
30
47
RPM IDLE
2000
3000
4000
Table 2: Using the Hi-Scan Pro in the OBD-II Menus Current Data Screen
TPS (%) 0
3.5
5.1
7.4
MAF (g/h) 2.8
6
8.5
12.7
RPM IDLE
2000
3000
4000
WITH MANUAL TRANSMISSION
Table 3: Using the Hi-Scan Pro in the Hyundai Diagnostic Menus Current Data Screen
TPS (%) 0
2.4
3.9
5.9
MAF (kg/h) 9.5
19.4
28.8
43
RPM IDLE
2000
3000
4000
Table 4: Using the Hi-Scan Pro in the OBD-II Menus Current Data Screen
TPS (%) 0
2.4
3.9
5.9
MAF (g/h) 2.5
5.5
8
12
RPM IDLE
2000
3000
4000
WARRANTY INFORMATION
Normal warranty applies.
