I bought recently on accent 2015 gls sedan used in Puerto Rico, came with the fog light, but since I bought it they did not turn me on, check cable and it's all original, I do not see the switch to turn them on, nevertheless the fuses are fine and all the cable is original. This model comes with factory fog lights! ....
The fog light switch should be on the left control stalk (for the headlights etc). The image below shows how to activate the lights.. If your stalk isn't the same then you don't have factory fogs...
thanks to both .... however the cable is as original and I do not have how to turn off and turn on the light lever.
The only other thing to try would be to visit a Hyundai dealer. They would be able to confirm whether or not your lights are correctly installed, and will be able to show you how to turn them on.
I doubt they would charge much for this.
