Accent 2013 misfires past 3200 rpm, Edit: fuel filter
Accent 2013 misfires past 3200 rpm under load and this has happened since I got this car last march (2017) (bought it used)
I measured the coils and all of them measure 1 Ω
The manual says it has to measure 0.75 Ω +/- 15%
so that´s 0.86 Ω
Anyway I changed already spark plugs and put the really expensive ones:
NGK 93815 SILZKR6B10E Laser Iridium Spark Plug
Also changed the 2 Oxygen sensors with the Denso original parts (bought them at rockauto.com) (Also the O2 sensors were really black at their tip...making me think it was running really rich), changed the air filter and put a can of fuel cleaner and then another of Seafoam to the gas tank.
Also, changed the manual transmission oil.
I´m in hot hot hot central america weather so I´m using Mobil 10w30
This made a huge increase in performance and also the car improved a lot the misfires to the point it only happens going under load uphill with the revs above 3200 RPM.
Compression is 165,168,168,165 psi (No smoke at all)
Also no CEL (check engine light ) on.
I´m running out of ideas.
Want to add some seafoam to the oil 300 miles before I change the oil.
What do you guys think ?
I bought this car used last year in March it was from a girl in New York (she left the papers and manuals in the glove box) and then someone imported to central america.
It seems this girl neglected some maintenance on it for quite a while.
My only complain are the misfires other than that the car runs really fine compared to my honda civic I´d say it is almost as fast as it. Being the difference the pull the civic has when pushing the gas pedal it is stronger and more firm. And the power the civic has when it goes uphill.
This is a very volcanic country so a lot of uphills and valleys.
Any help is really appreciated.
Thank you for your time to read and reply.
EDIT:
also forgot to ask, does this car uses a fuel filter in tank ? like the civic?
The civic does uses a fuel filter and it is a replaceable/serviceable part the only issue with it is you have to remove the back seat and pull the fuel pump assembly. Then change the filter from the assembly.
Rockauto sells the filter for the civic ( More Information for BECK/ARNLEY 0433012 ) and I was expecting to see a fuel filter for the accent but can´t seem to find one on rockauto or other place online and even I´m conscious a fuel additive cleaner cleans I too know the fuel filter inside the tank clogs over time.
Given my experience with my civic I can say it does really help changing the fuel filter even if you frequently use fuel cleaner additives that´s not enough and it won´t be as putting a new fuel filter.
EDIT #2:
obviously this guy thinks it is built to last 20+ years (that´s the time I keep cars) He is so wrong thinking it will last like that with the gas quality in central america....lol ! that´s a joke!
https://www.justanswer.com/hyundai/7sm9p-hyundai-fuel-filter-gas-tank-fuel-pump.html
so that´s 0.86 Ω
EDIT:
EDIT #2:
