i have had a boggy problem for months and cant find the problem i changed the injectors the coils the plugs cleaned all the sensors and no change at all at low RPM like under 3000 when its cold it sounds like it wants to stall when hot its boggy from time to time like one min its ok then 2 minutes later its boggy
No codes? Are you throwing parts at it or is a shop doing this? How many miles?
00000732
* Do a search for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
the garage never told me any codes they just told me oh change this oh it didnt work?.... ok lets change this....
thats what im getting at the garage .. and its getting way too expensive i just want help
2007 Honda CRV
Try idling the car with the gas cap off
Try taking out the up stream O2 sensor out and idling the engine
You have your car at the wrong place. Don't even bother with the O2 sensor he's telling you to remove. Take pictures of the bills for your repairs and post them so I can see what they actually did.
