1 - 1 of 1 Posts
I just replaced my transmission with a used unit and now have a bunch of extra parts I do not have space for.
The is most likely a good amount of internal damage to the gears and synchros from a bad input shaft bearing.
It might even be able to be rebuilt (considering a new transmission is $1700 from hyundai) I believe the gears are $100-200 each)
I am located in western Massachusetts.
That being said some of the possible parts that might be of use to someone I have are:
flywheel (has been machined once, but have heard then can be done twice)
clutch plate mounting bolts
transmission case
neutral switch
reverse switch
fill/drain plugs
front and rear mount brackets
power steering side rubber mount
upper transmission mount block
old style clutch release bearing (new)
shift linkage bracket
1 - 1 of 1 Posts
