Hi,
My Grand i10 1.2 Petrol is 5 yrs old. Recently it seems that the acceleration is not smooth. The tachometer shows increase in rpm once I push the accelerator buy the pick up is not taking up comparatively. Also, the gear shift indicator is showing wrong indication many a time if not always. As in, even when I'm in 4th gear, it shows to shift up the gear to 4th gear and so on.
Hi, as no one else seems to be replying.... here goes. It sounds to me like a slipping clutch. There could be several reasons from a poorly lubricated cable to an internal oil seep, but the most lightly is just a worn clutch plate. It would need a mechanic to look at it, and he will tell you straight away.
