my elantra fan runs on high only I was thinking about replaving the reziter 40 bucks us but the fan is wet and when i turn to the left water drips from the AC inside could the hose be clogged or is there somthing else doing this thanks for your repelys
QUOTE (haircutt @ May 26 2010, 02:29 PM) index.php?act=findpost&pid=326595
my elantra fan runs on high only.
ok
Not heard of a reziter, but there is a fan speed resistor near the fan motor
40 bucks us
$40 (USD)
but the fan is wet and when i turn to the left water drips from the AC inside,, could the hose be clogged or is there somthing else doing this ??
Spider or other has likely clogged the drain tube from the HVAC, you need to clear the line so the condensate from evaporator can drain out.
Easiest is to have car in the air.
