noticed rumbling/grinding noise when driving car or idling and initially thought it was the water pump or ac compressor. I isolated noise to the ac compressor using a mechanics stethoscope. My ac works fine and there is no difference in noise if ac is switched on or off.
Has anyone had experience replacing the bearing with ac compressor still on the car? I don't want to have to mess with discharge/re-charging ac. Id like to try using a puller to remove pulley and press in a new bearing since my ac compressor is running fine.
