1 - 1 of 1 Posts
My Hyundai 2001 Sonata 4 cyl AC is warm, I thought at first it needed a recharge of R134a , it only took 1/3 of a can I noticed the clutch wasn't turning on the compressor , so what's next where are the high and low pressure switches located or the compressor cut off switch , I checked all the 10 amp fuses all good?
if I check the resistance across the 2 wires coming out of the AC compressor clutch what should it read?
really need help bad its hot outside. :surprise:
1 - 1 of 1 Posts
