1 - 8 of 8 Posts
Almost EVERY time I come to a stop, within the last couple of feet my ABS activates. ,no other issues with the braking.
I have a similar problem. Low speed (almost stopped, for instance pulling in to a parking bay) occasionally at roundabouts and junctions. It's my wife's car and she gets panicky because the brakes are less effective. By taking foot off the brake and repaying usually cures it. Problem is she is now nervous about driving it. I bet it's an arm and a leg to fix as well. Any advice for me and the OP?
I have a similar problem. Any advice for me and the OP?
I guess it will be a little too late for the OP, but the symptoms your describing are usually caused by a broken/cracked ABS tone wheel...
Thanks for that. Next question is it an expensive fix? The sort of thing that gives a hyundai dealer an opportunity to rip your cash.?
Usually it's not. On most cars the tone wheel can be replaced fairly easily. I'm not sure if the tone wheel is available from Hyundai as a separate part though, so a dealer might want to replace the complete driveshaft which will obviously make it much more expensive. Dealers don't usually like to use aftermarket parts, so having the repair done at your local independent garage will probably be the better/cheaper option.
Ok cheers. I have seen them on ebay for less than a tenner. Just have to check that's the problem and that they fit. So might enlist a mobile mechanic. Hes quoting me £60 a side. Hyundai rates are about £120 an hour
Alternatively, is it possible to disengage the ABS and just go back to good old ordinary brakes? Shes never above 30mph and on good roads. Any whiff of snow or ice and I'm on driving duty to ferry her to work. If it's legal and wont affect MOT I'd be happy to throw it in the bin
When you disable the ABS the warning light stays on, which is an MOT failure.
1 - 8 of 8 Posts
