I think having the ABS module scanned to read the trouble code that's being logged will give you a big clue.
Scan ABS/ESC... let module output the DTC to indicate which of many input - output circuit the module seen to be at fault.. may not be an ABS sensor ...
Need code to look up in the Hyundai menu to know what circuit seen to have fault
Good day, same has happened to me no code was present and driving with no bad effects.
The light was on telling you there was a fault but the module didn't log a code to explain what the fault was?
So what did you do to to make the light stay off again then, and how did you figure it out without a trouble code?
