2011 Santa Fe Fwd. Abs and traction lights are on. Carried it to a garage and the hooked up to it. It said the left rear wheel sensor was open or shorted. I replaced the wheel hub and bearing assembly that has the sensor built in. The lights were still on. Disconnected the battery and connected it back. The lights stayed out for a day and now are back on. No prior work has been done on this vehicle
That's OK, no harm done.
Your other thread is in the same forum as this thread, which is the correct place for posts relating to your model.
